You are here: FME Server Administrator's Guide > Common Configurations > Purging Logs and History
As FME Server processes jobs, the history of these jobs is stored as records in the repository database and as log files in the file system. Eventually, the volume of these records and logs can build up and cause issues, such as slow web interface response time and low disk space. Therefore, FME Server ships with two workspaces that you can scheduled to purge job history from the database and log files from the file system.
To enable scheduled purging:
  1. Log into the Web User Interface:
    http://<host>/fmeserver
  2. Click the Schedules tab.
  3. Then:
  4. To adjust the frequency of the purging, select the schedule, click Configure, and then adjust the repeat interval and frequency.
